Problems with updater
oerlemans
When I will update plesk through the web interface I get 'Error: There is no suitable releases.'
When I run ' rsync autoinstall.plesk.com::autoinstall' at the command line I get 'rsync: getaddrinfo: autoinstall.plesk.com 873: Temporary failure in name resolution'
Do you have any idea what the problem is??
I have same problem on psa v8.1.1_build81070423.15 os_RedHat el4, someone can help us?
Thanks
321go
Hi oerlemans,
Can you advice how to solved the updater problem? Please.
Thanks
321go
